- To:
- Subject: Re: [cgal-discuss] 3d lines intersection point
- Date: Wed, 03 Jan 2007 12:17:36 +0100
Hi Cedric,
this is not implemented.
andreas
Cédric LE MAITRE wrote:
Hi,
And happy new year to every CGAL users.
i want to compute the intersection point of 2 3D lines.
i try this code:
Point_3 ptC1(-4, 0, 0);
Point_3 ptP1(-3, 0.25, 0.25);
Point_3 ptC2(0, -4, 0);
Point_3 ptP2(0.25, -3, 0.25);
Line_3 line1(ptC1, ptP1);
Line_3 line2(ptC2, ptP2);
CGAL::Object result;
result = Kernel::Intersect_3(line1, line2);
Point_3 ptR;
if (CGAL::assign(ptR, result)) {
// handle the point intersection case.
But it don't compile. i didn't found example which use this function.
Please how could i do that ?
Thanks,
Cedric LE MAITRE
--- You are currently subscribed to cgal-discuss.
- 2D segment-circle intersection?, Malcolm Ryan, 01/03/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Monique Teillaud, 01/03/2007
- 3d lines intersection point, Cédric LE MAITRE, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Andreas Fabri, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Vikas, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Hua Lu, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/05/2007
- Re: [cgal-discuss] 3d lines intersection point, Monique Teillaud, 01/04/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/29/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/30/2007
