- To:
- Subject: Re: [cgal-discuss] 2D segment-circle intersection?
- Date: Mon, 29 Jan 2007 15:43:42 +1100
On 29/01/2007, at 3:09 PM, Malcolm Ryan wrote:
As far as I can see, the Do_intersect test should be reasonably simple:
Consider the distance d from the centre of the circle to the line defined by the segment.
If (d > radius) return 0 solutions
if (distance(centre, source) < radius) then
if (distance(centre, target) < radius) return 0 solutions;
else return 1 solution;
else if (distance(centre, target) < radius) then
return 1 solution;
else
construct a line perpendicular to the segment, passing through the centre of the circle
if (source and target are on the same side of this line) return 0 solutions
else if (d == radius) return 1
else return 2 solutions.
This should all be doable with existing predicates in the 2d kernel, except for the construction of the perpendicular line in the fourth line from the bottom. I can't see any easy way to avoid that, without resorting to algebra.
Aha. It can be replaced with an angle() test which sees if the angle given by (source, target, centre) is obtuse (no solutions) or acute (1 or 2 solutions).
Malcolm
"Cleanliness is not next to godliness nowadays,
for cleanliness is made an essential
and godliness is regarded as an offence.
- G.K.Chesterton, On Lying in Bed
- 2D segment-circle intersection?, Malcolm Ryan, 01/03/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Monique Teillaud, 01/03/2007
- 3d lines intersection point, Cédric LE MAITRE, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Andreas Fabri, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Vikas, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Hua Lu, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/05/2007
- Re: [cgal-discuss] 3d lines intersection point, Monique Teillaud, 01/04/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/29/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/30/2007
