- To:
- Subject: Re: [cgal-discuss] 3d lines intersection point
- Date: Thu, 04 Jan 2007 09:50:15 +0100
Hi,
not an answer, but just an information: there is an implementation of this functionality in the 3d circular kernel, which is currently submitted to the CGAL editorial board.
(I cannot post the implementation here, because it is not a single stand-alone implementation, it is integrated in the whole submited kernel with pieces distributed in lots of files...)
Monique Teillaud
Andreas Fabri wrote:
Hi Cedric,
this is not implemented.
andreas
Cédric LE MAITRE wrote:
Hi,
And happy new year to every CGAL users.
i want to compute the intersection point of 2 3D lines.
i try this code:
Point_3 ptC1(-4, 0, 0);
Point_3 ptP1(-3, 0.25, 0.25);
Point_3 ptC2(0, -4, 0);
Point_3 ptP2(0.25, -3, 0.25);
Line_3 line1(ptC1, ptP1);
Line_3 line2(ptC2, ptP2);
CGAL::Object result;
result = Kernel::Intersect_3(line1, line2);
Point_3 ptR;
if (CGAL::assign(ptR, result)) {
// handle the point intersection case.
But it don't compile. i didn't found example which use this function.
Please how could i do that ?
Thanks,
Cedric LE MAITRE
--- You are currently subscribed to cgal-discuss.
- 2D segment-circle intersection?, Malcolm Ryan, 01/03/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Monique Teillaud, 01/03/2007
- 3d lines intersection point, Cédric LE MAITRE, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Andreas Fabri, 01/03/2007
- Re: [cgal-discuss] 3d lines intersection point, Vikas, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Hua Lu, 01/04/2007
- Re: [cgal-discuss] 3d lines intersection point, Cédric LE MAITRE, 01/05/2007
- Re: [cgal-discuss] 3d lines intersection point, Monique Teillaud, 01/04/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/29/2007
- Re: [cgal-discuss] 2D segment-circle intersection?, Malcolm Ryan, 01/30/2007
