cgal-discuss - Re: [cgal-discuss] Delaunay Questions
  • To:
  • Subject: Re: [cgal-discuss] Delaunay Questions
  • Date: Thu, 14 Jun 2007 19:35:27 +0200
Robert Bryce a écrit :
These should be easy questions. I need to generate 2-D Delaunay and Voronoi diagrams.
I’ve got a current code set based on that written by Olivie Devillers some 10 years ago. I used his code because it was fast and would allow me to dynamically add and remove points. However, I’ve found that this (older) code (about 10 years old) will endless loop on occasion, as well as crash.
My needs have also changed – I need to handle barriers now. I’m also dealing with so many points (easily 25,000+) that I either need a much faster serial operation or (preferred) a multithreaded solution. Does the CGAL solution allow me to dynamically add and remove points (it appears so),
It does.
> and possibly even insert barriers (not so sure), while
keeping handle for each vertex back to my own structures?
If by "barrier" you mean a segment which is a constraint, then yes.
You can have a look at the constrained triangulation and possibly
Mesh_2 packages of CGAL to get a better idea if what CGAL provides
fits your needs.
> Is there any opportunity to multithread the CGAL code?
Currently no, but in some future, most probably.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
