- To:
- Subject: Re: [cgal-discuss] Voronoi-/Power- diagram 3D
- Date: Wed, 01 Aug 2007 10:21:18 +0200
schrieb:
Bernhard Kornberger wrote:
schrieb:
Is it true that I have to implement the conversion from
the power diagram to a graph of the power diagram by myself
or is there already a function that I didn't find?
The graph is dual to the triangulation (up to degeneracies), do you need to convert the triangulation to its dual that you would store in addition ?
Monique
Right. I need a function like this:
Regular_triangulation Tr;
Tr.insert(p1);
Tr.insert(p2);
Tr.insert(p3);
Tr.insert(p4);
UndirectedGraph g=Tr.dual();
..such that I can traverse along the edges of $g afterwards.
but you can traverse edges of g by just following adjacency relations between tetrahedra in Tr, without storing g.
Monique
I need functions like breath-first search on the edges of the
power diagram and I need to label edges as already visited or
not. This is complicated to implement (and horrible to debug)
if the power-diagram is not explicitly given as a graph.
Best
Bernhard
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Monique . Teillaud, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Bernhard Kornberger, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Andreas Fabri, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Laurent Rineau, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Michael Balzer, 08/01/2007
