cgal-discuss - Re: [cgal-discuss] Voronoi-/Power- diagram 3D
  • To:
  • Subject: Re: [cgal-discuss] Voronoi-/Power- diagram 3D
  • Date: Wed, 01 Aug 2007 10:29:06 +0200
Bernhard Kornberger wrote:
schrieb:
Is it true that I have to implement the conversion from
the power diagram to a graph of the power diagram by myself
or is there already a function that I didn't find?
The graph is dual to the triangulation (up to degeneracies), do you need to convert the triangulation to its dual that you would store in addition ?
Monique
Right. I need a function like this:
Regular_triangulation Tr;
Tr.insert(p1);
Tr.insert(p2);
Tr.insert(p3);
Tr.insert(p4);
UndirectedGraph g=Tr.dual();
..such that I can traverse along the edges of $g afterwards.
but you can traverse edges of g by just following adjacency relations between tetrahedra in Tr, without storing g.
Monique
I need functions like breath-first search on the edges of the
power diagram and I need to label edges as already visited or
not. This is complicated to implement (and horrible to debug)
if the power-diagram is not explicitly given as a graph.
I agree that you need to store the graph as some graph data structure of the BGL if you want to use directly some existing BGL algorithms. This is maybe what you mean.
But if you are implementing the traversal yourself, then the graph is already _explicitly_ given, since adjacency relations between cells of the triangulation are explicitely stored.
And you can mark facets of the triangulation by adding marking into the cells of the triangulation (but in fact marks will be duplicated in this way).
A traversal of the power graph along its edges is exactly the same as the traversal of the cells of the triangulation using these adjacency relations.
Monique
