- To:
- Subject: Re: [cgal-discuss] Voronoi-/Power- diagram 3D
- Date: Wed, 1 Aug 2007 10:47:44 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Wednesday 01 August 2007 10:29:06
wrote:
> I agree that you need to store the graph as some graph data structure of
> the BGL if you want to use directly some existing BGL algorithms. This
> is maybe what you mean.
Actually, to use the BGL you do not need to duplicate the graph stored in the
Delaunay triangulation. You only need to create a sort of traits class, that
maps the API of the Delaunay triangulation to the API need by BGL algorithms.
Bernhard, as said Monique, all the combinatorial information of the Voronoi
diagram is already in the Delaunay triangulation. If you also need the
geometric information of the Voronoi diagram, you can generate it on-the-fly
during your traversal.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Monique . Teillaud, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Bernhard Kornberger, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Andreas Fabri, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Laurent Rineau, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Michael Balzer, 08/01/2007
