- To:
- Subject: Re: [cgal-discuss] Voronoi-/Power- diagram 3D
- Date: Wed, 01 Aug 2007 10:40:48 +0200
Hi Bernhard,
If you implement it anyway as you need it, and CGAL doesn't offer it,
you might implement a graph_traits and the some global functions
to explore adjacencies in a graph, so that the Voronoi diagram
becomes model of a boost::graph.
You can see how to do this in the chapter http://www.cgal.org/Pkg/BGL
The advantage is that you then can use the algorithms of the BGL
on this graph.
And if once you done you contribute it back.....
andreas
OK, I'll do it that way. I'm going to attend the ACS workshop in
Antibes and on Monday and Tuesday afterwards (Oct. 1st, 2nd) I
will visit Inria. Maybe we can talk about the implementation
then.
Best
B
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Monique . Teillaud, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Bernhard Kornberger, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Andreas Fabri, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Laurent Rineau, 08/01/2007
- Re: [cgal-discuss] Voronoi-/Power- diagram 3D, Michael Balzer, 08/01/2007
