- To:
- Subject: Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem
- Date: Fri, 28 Sep 2007 08:15:38 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
> > I am puzzled by this because the manual says that
> > Induced_edge_iterator returns a halfedge handle, and this does have a
> > curve() function, doesn't it?
> I believe it says that the value type of Induced_edge_iterator is
> Halfedge_handle, so the correct statement should be:
> std::cout << (*eit)->curve() << std::endl;
<slaps his head>
Thanks a bunch, works like charm now.
Regards,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/26/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efi Fogel, 09/26/2007
- Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/27/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Efi Fogel, 09/28/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/28/2007
