- To:
- Subject: Re: [cgal-discuss] efficiency of the point-in-polyhedron test
- Date: Wed, 10 Oct 2007 09:37:29 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Wednesday 10 October 2007 03:24:21 Dr. Liu Jianfei wrote:
> Dear Colleagues,
> I am using Nef_polyhedron_3 and its function locate(Point_3) for
> point-in-polyhedron test for polyhedrons composed of triangles. However the
> time to create a Nef_polyhedron_3 is very cost and always fail when the
> number of triangles is more than 4,000. In fact, I have just developed a
> new point-in-polyhedron algorithm, it aims to treat large scale problems( a
> lot of tests with respect to models composed of huge number of triangles).
> It is much efficient comparing with results found in literatures.However I
> need some other codes to do comparison directly and I wounder if the
> function locate in CGAL is the suitable one. By the way, I'd like to add
> the codes into CGAL if it is possible. Thanks a lot.
Dear Dr. Liu Jianfei,
I would need that kind of code. Do you plan to release the code under a
license compatible with CGAL's one? If the answer is yes, can you send me the
current code, so that I can evaluate that code as a tool in my algorithms
(for the 3D Surface Mesh Generator, in CGAL)?
I am very interrested by that functionality. As a CGAL developer, I can work
with you to integrate your code in CGAL, and co-maintain it with you, if you
agree.
Best regards,
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Laurent Rineau, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Matthijs Sypkens Smit, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Laurent Rineau, 10/16/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Matthijs Sypkens Smit, 10/16/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/16/2007
