- To:
- Subject: Re: [cgal-discuss] efficiency of the point-in-polyhedron test
- Date: Tue, 16 Oct 2007 11:29:37 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Wednesday 10 October 2007 11:53:50 Matthijs Sypkens Smit wrote:
> Using a CGAL Nef polyhdron to do inside/outside tests on a polyhedron is
> relatively inefficient in my experience. From the limited tests that I did
> with some triangulated models it was in the order of 10000 times slower
> than using a (constrained) Delaunay triangulation. Another very fast
> method is the use of a binary space partition of your triangulated models.
> Both methods (Delaunay and BSP) have the drawback that the initial data
> structure is hard to create.
Mister Sypkens Smit, do you have an implementation of such a data structure,
that is usable for that task?
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Laurent Rineau, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Matthijs Sypkens Smit, 10/10/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Laurent Rineau, 10/16/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Matthijs Sypkens Smit, 10/16/2007
- Re: [cgal-discuss] efficiency of the point-in-polyhedron test, Dr. Liu Jianfei, 10/16/2007
