cgal-discuss - Re: [cgal-discuss] efficiency of the point-in-polyhedron test
  • To: <>
  • Subject: Re: [cgal-discuss] efficiency of the point-in-polyhedron test
  • Date: Wed, 10 Oct 2007 17:27:11 +0800
  • Subject-xx:
Dear Dr. Laurent Rineau,
I am glad that you also need such a function. I will send the code to you in
three or four days' time.
Liu Jianfei
> Dear Dr. Liu Jianfei,
> I would need that kind of code. Do you plan to release the code under a
> license compatible with CGAL's one? If the answer is yes, can you send me
> the
> current code, so that I can evaluate that code as a tool in my algorithms
> (for the 3D Surface Mesh Generator, in CGAL)?
> I am very interrested by that functionality. As a CGAL developer, I can
> work
> with you to integrate your code in CGAL, and co-maintain it with you, if
> you
> agree.
> Best regards,
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
