cgal-discuss - Re: [cgal-discuss] efficiency of the point-in-polyhedron test
  • To:
  • Subject: Re: [cgal-discuss] efficiency of the point-in-polyhedron test
  • Date: Tue, 16 Oct 2007 12:01:58 +0200
On Tuesday 16 October 2007 11:29, Laurent Rineau wrote:
> On Wednesday 10 October 2007 11:53:50 Matthijs Sypkens Smit wrote:
> > Using a CGAL Nef polyhdron to do inside/outside tests on a polyhedron
> > is relatively inefficient in my experience. From the limited tests
> > that I did with some triangulated models it was in the order of 10000
> > times slower than using a (constrained) Delaunay triangulation.
> > Another very fast method is the use of a binary space partition of
> > your triangulated models. Both methods (Delaunay and BSP) have the
> > drawback that the initial data structure is hard to create.
> Mister Sypkens Smit, do you have an implementation of such a data
> structure, that is usable for that task?
Dear Laurent,
I do not have an implementation of a 3D BSP. For the construction of
constrained Delaunay triangulations I have been using Tetgen[1]. Tetgen
creates the triangulation and from Tetgen's datastructure I construct a
CGAL Triangulation, that is effectively a CDT. Drawback is that I had to
make a small modification to the Tetgen source. I think it should be
possible to do it without the modification, but I don't have that
currently. Also, Tetgen fails on some models. I have not investigated it
in detail, so I cannot be sure if it is the robustness of Tetgen or that
the fault lies with the models.
1] http://tetgen.berlios.de/
So, I guess the answer depends on your definition of "usable for the task".
If you are still interested, I can send you code/instructions privately.
It is by no means suitable for release or incorporation into CGAL.
I have also partly implemented the algorithm of Cohen-Steiner/de
Verdière/Yvinec for creating a conforming Delaunay triangulation. This is
not finished yet, but it is very slow and resource-intensive on large
models (containing a lot of triangles). It also tends to yield many more
elements than you originally started with.
