- To:
- Subject: Re: [cgal-discuss] A compiler Error
- Date: Thu, 29 Nov 2007 19:31:57 +0800
Simao Soares wrote:
I'm having problems with Visual c++ Express Edition 2005 and CGAL.
I too have seen the "This application has failed to start because of the application configuration is incorrect." error with VC++ Express Edition.
I can't help you but here are some observations in case anyone's interested:
* My main workstation (1) has both VS 2005 and VC++ EE. However, I use CGAL with VC++ EE (mainly because it's fast and has a simpler UI) and have no problems on this machine.
* My other workstation (2) (seldom used) has only VS 2005. If I take a VC++ EE CGAL solution from 1 to this one and try to compile it with VS 2005, there are no problems. However, when I run the application I see the "application config" error. And here's the weird part -- it happens only with the debug build. A release build .exe runs without problems.
I know the above problem is related somehow to SxS issues, but I haven't had the time+energy to figure it out.
~ash
- A compiler Error, sinan mutlu, 11/19/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/19/2007
- Re: [cgal-discuss] A compiler Error, sinan mutlu, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Simao Soares, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Ashwin Nanjappa, 11/29/2007
