- To: <>
- Subject: Re: [cgal-discuss] A compiler Error
- Date: Mon, 19 Nov 2007 17:12:48 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:from:to:references:in-reply-to:subject:date:organization:mime-version:content-type:content-transfer-encoding:x-priority:x-msmail-priority:x-mailer:x-mimeole; b=kD117GxupW/YrBg8KbTqvYajuNEPCMGrovDcaoasbrkY76sHmv5QHKdoLBBqpBW3Nhzp+jzlFUB2qdvwgtduuHbV7zW5JfoA27B+F4EjYtliLiP03ABEqnU/Wvm6trExBSxatLLdoriNYdlii881EJkmNzxKLE4oDiZeuTP2WTM=
- Organization: SciSoft
Hello sinan,
Hi,I can't reproduce the problem here.
I am trying to compile & run the "straight_skeleton_2" example. It compiles
successfully but while compiling it it gives 83 warnings like:
Warning 1 warning LNK4099: PDB 'vc80.pdb' was not found with
'D:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at
'd:\Program Files\CGAL-3.3.1\examples\Straight_skeleton_2\VC\Debug\vc80.pdb';
linking object as if no debug info gmp-vc80-mt-gd.lib
Can you post the time stamps for these files:
gmp-vc80-mt-gd.lib
gmp-vc80-mt-gd.pdb
TIA
Fernando Cacciola
GeometryFactory
- A compiler Error, sinan mutlu, 11/19/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/19/2007
- Re: [cgal-discuss] A compiler Error, sinan mutlu, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Simao Soares, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Ashwin Nanjappa, 11/29/2007
