- To:
- Subject: Re: [cgal-discuss] A compiler Error
- Date: Tue, 20 Nov 2007 14:22:04 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=cRO0hZfW0bEKTL/RA5gZoRz9ysBgugNe63peNWmiQVonfCF9y7G9SiprFFBA7AUKObjWVCY141ZQl549TxIrbym4QR4jVScLcOrJPJDsYgrUaiZYjFDjqz6vrN+JbEtjBK5bUVDwYZUJ1ELfJ0f6s3qjAgb04iylbjvvkU5GaAM=
It's not possible to use CGAL with Express edition?
What versions of Visual Studio can be used with CGAL?
On Nov 20, 2007 1:47 PM, Fernando Cacciola <> wrote:
Hi sinan,
Can you confirm the following?
1) You are installing from the CGAL-3.3.1 windows installer as found on the CGAL
site.
2) You are using Visual Studio 2005, NON-express version
3) You are using the precompiled libraries downloaded by the installer as-is,
*including* those for CGAL itself. That is, you did not re-build CGAL manually
and instead build the example directly.
4) You converted the Straight_skeleton_2.vcproj using the Project Conversion
Wizard of VS2005 (when trying to open it from VS2005)
Also, can you open a command prompt and do this:
cd 'D:\Program
Files\CGAL-3.3.1\examples\Straight_skeleton_2\VC\Debug\Straight_skeleton_2"
dir > files.txt
then attach "files.txt " along with these files (found on that folder):
Straight_skeleton_2.exe.embed.manifiest
Straight_skeleton_2.exe.intermediate.manifiest
in a new post?
TIA
Fernando Cacciola
GeometryFactory
Simão Soares
Student at University of Minho, Portugal
GNU/Linux Portugal Co-founder http://www.gnulinux-portugal.org
LinkedIn: http://www.linkedin.com/in/simaosoares
Webpage: http://simao.lusosystems.com/
Phone: +351 918 656 143
- A compiler Error, sinan mutlu, 11/19/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/19/2007
- Re: [cgal-discuss] A compiler Error, sinan mutlu, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Fernando Cacciola, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Simao Soares, 11/20/2007
- Re: [cgal-discuss] A compiler Error, Ashwin Nanjappa, 11/29/2007
