cgal-discuss - Re: [cgal-discuss] A compiler Error
  • To:
  • Subject: Re: [cgal-discuss] A compiler Error
  • Date: Tue, 20 Nov 2007 11:47:38 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=cKFjRVTmMqmCBb801X+pFjswozu1/jTFRGzDlPgfBsPg/bkgu4SXB3SwVtGvGXYfT7XIxdK+kDCozZCKYgs7eZ6m7UyDpN14dZcuPHE7EVjP5tx0vtJAMUh+r/0gGEGGXDPmF0tJNpoJT1N7ZWkt+Unr5FSWqRArYmc5fkQ3DQg=
Hello Fernando,
I will send the timestamp of those files you want from me but I do not know how to get the time stamps of the files.
Sinan MUTLU
On 19/11/2007, Fernando Cacciola <> wrote:
Hello sinan,
> Hi,
> I am trying to compile & run the "straight_skeleton_2" example. It compiles
> successfully but while compiling it it gives 83 warnings like:
> Warning    1    warning LNK4099: PDB ' vc80.pdb' was not found with
> 'D:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib' or at
> 'd:\Program Files\CGAL-3.3.1\examples\Straight_skeleton_2\VC\Debug\vc80.pdb';
> linking object as if no debug info     gmp-vc80-mt-gd.lib
I can't reproduce the problem here.
Can you post the time stamps for these files:
gmp-vc80-mt-gd.lib
gmp-vc80-mt-gd.pdb
TIA
Fernando Cacciola
GeometryFactory
