cgal-discuss - Re: [cgal-discuss] Question about mesh simplification
  • To: <>
  • Subject: Re: [cgal-discuss] Question about mesh simplification
  • Date: Thu, 29 Nov 2007 14:27:40 -0300
  • Organization: Geometry Factory
Hello Pablo,
Hi, every one, I'm trying to use CGAL to simplify a mesh which is already
simple, but has some unnecessary edges. The mesh is a model created by 3d
MAX of a building. The walls hav sometimes many triangles in it which adds
many unnecessary edges... My goal is to remove this triangles.. a simple
test is to check if adjacent triangle has very near normals, but I dont want
to do this by my self, im trying to use cgal to do something like this. I
have taken all triangles from the model and I've added it to a Polyhedron
just like in the examples provided in the official website (Polyhedron P;
P.make_triangle( P1, P2, P3) .... for each triangle)...
The result is that no edges were removed... so I don't know what do i need
to do.. My polycies are :
SMS::Edge_length_cost and SMS::Midpoint_placement using the ratio stop
criteria... Shouldn't the walls composed by many triangles be simplified?
What's the stop condition?
What happens if you use the LindstromTurk policies?
(which btw are much more likely to give you the expected results)
HTH
Fernando Cacciola
GeometryFactory
