- To:
- Subject: Re: [cgal-discuss] Question about mesh simplification
- Date: Thu, 29 Nov 2007 15:51:47 -0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=kqT+xPJsJyGFoUbNj8TT3l1YWlUL/jTYMo82sBizCQsFP9rkqNmLK0QqPrReZyKJWIGTi2l60gN7RNqKs7o/UKV3xzSdU6I2ags7dlvWocV23lpawMIIHAJ+F/hMYUgrkSQq1Dn5piSPLW70DikS7vjUR91HDf0ijIx4R3YdW/s=
Hi, thanks for the fast reply... I've tried it using the default criteria too (LindstromTurk) and the stop criteria as Count_stop_predicate. But the result was the same... no edges removed... I'm importing the model from the OpenSceneGraph loader and then for each triangle in the model I'm pushing it to a Polyhedron_3: here's how I create the triangles within the Polyhedron:
(The below function is called for each triangle in the model)
inline void operator() ( const osg::Vec3 &v1, const osg::Vec3 &v2, const osg::Vec3 &v3, bool )
if ( &v1 == &v2 || &v1 == &v3 || &v2 == &v3 )
return;
_p->make_triangle(
CGAL::Point_3<Kernel>( v1[0], v1[1], v1[2] ),
CGAL::Point_3<Kernel>( v2[0], v2[1], v2[2] ),
CGAL::Point_3<Kernel>( v3[0], v3[1], v3[2] )
then, by this point all triangles were pushed into the Polyhedron named 'P'.. it is going to be used below...
// This is a stop predicate (defines when the algorithm terminates).
// In this example, the simplification stops when the number of undirected edges
// left in the surface drops below the specified number (1000)
SMS::Count_stop_predicate<Surface> stop(1000);
// This the actual call to the simplification algorithm.
// The surface and stop conditions are mandatory arguments.
// The index maps are needed because the vertices and edges
// of this surface lack an "id()" field.
int r = SMS::edge_collapse
(P
,stop
,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,P))
.edge_index_map (boost::get(CGAL::edge_external_index ,P))
std::cout << "\nFinished...\n" << r << " edges removed.\n"
<< (P.size_of_halfedges()/2) << " final edges.\n" ;
No edges were removed... but rendering the model using lines I can see there are many walls composed by many triangles combined together, and so there many "removable" edges that I wish to remove...
thanks
[]'s
2007/11/29, Fernando Cacciola <>:
Hello Pablo,
> Hi, every one, I'm trying to use CGAL to simplify a mesh which is already
> simple, but has some unnecessary edges. The mesh is a model created by 3d
> MAX of a building. The walls hav sometimes many triangles in it which adds
> many unnecessary edges... My goal is to remove this triangles.. a simple
> test is to check if adjacent triangle has very near normals, but I dont want
> to do this by my self, im trying to use cgal to do something like this. I
> have taken all triangles from the model and I've added it to a Polyhedron
> just like in the examples provided in the official website (Polyhedron P;
> P.make_triangle( P1, P2, P3) .... for each triangle)...
> The result is that no edges were removed... so I don't know what do i need
> to do.. My polycies are :
> SMS::Edge_length_cost and SMS::Midpoint_placement using the ratio stop
> criteria... Shouldn't the walls composed by many triangles be simplified?
What's the stop condition?
What happens if you use the LindstromTurk policies?
(which btw are much more likely to give you the expected results)
HTH
Fernando Cacciola
GeometryFactory
- Question about mesh simplification, Pablo Carneiro Elias, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Fernando Cacciola, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Pablo Carneiro Elias, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Pablo Carneiro Elias, 11/30/2007
