- To:
- Subject: Re: [cgal-discuss] Question about mesh simplification
- Date: Thu, 29 Nov 2007 18:32:52 -0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=Q1zSpWrg0L7xyHuciibrxwnlTJ/UX4l1J2MgDSTxU3omY9WrtFa0lj2ezs6PSnUS/CvVBy77J/xaNlHcpFXD8paBY+AYz4zbZtfFv3bkULK85xtHldoi7PojB6dgBCGxE0ymyKsDSSBA5DD4+m9GBYSU9z/QT/5NKKZrWaHm41Q=
Sure, I've saved my polyhedron to a file using the stream operator of the Polyhedron class, I'm sending it with a cpp file which opens it and runs the default simplification.. thanks!
[]'s Pablo
2007/11/29, Fernando Cacciola <>:
Hello Pablo,
Can you post a short program that I could compile and test myself?
> SMS::Count_stop_predicate<Surface> stop(1000);
That means that if the mesh has less than 1000 edges, none will be removed.
Your mesh has more than 1000 edges right?
Best
Fernando Cacciola
GeometryFactory
MeshSimplificationTriangles-Pablo.rar
Description: application/rar
- Question about mesh simplification, Pablo Carneiro Elias, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Fernando Cacciola, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Pablo Carneiro Elias, 11/29/2007
- Re: [cgal-discuss] Question about mesh simplification, Pablo Carneiro Elias, 11/30/2007
