- To:
- Subject: Re: Re: [cgal-discuss] CGAL and Ubuntu
- Date: Sun, 2 Dec 2007 17:13:27 +0100
>Works perfectly fine on ubuntu 7.10 and 7.04 here, just using
>"./install_cgal --prefix=/usr/local" from the unpacked CGAL dir. Are
>you sure g++ is installed? What is the output of "g++ --version"?
Thanks for you help, g++ was not installed:
mahmood@magma:~/CGAL-3.3.1$
g++ -v
The program 'g++' can be found in the following packages:
* g++
* pentium-builder (You will have to enable component called 'universe')
Try: sudo apt-get install <selected package>
bash: g++: command not found
but gcc is installed:
gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v
--enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr
--enable-shared --with-system-zlib --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --enable-nls
--with-gxx-include-dir=/usr/include/c++/4.1.3 --program-suffix=-4.1
--enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug
--enable-mpfr --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)
- Re: Re: [cgal-discuss] CGAL and Ubuntu, nt_mahmood, 12/02/2007
- <Possible follow-up(s)>
- Re: [cgal-discuss] CGAL and Ubuntu, Laurent Rineau, 12/03/2007
- Re: [cgal-discuss] CGAL and Ubuntu, Mahmood NT, 12/11/2007
- Re: [cgal-discuss] CGAL and Ubuntu, Joachim Reichel, 12/11/2007
- Re: Re: [cgal-discuss] CGAL and Ubuntu, nt_mahmood, 12/11/2007
- Re: [cgal-discuss] CGAL and Ubuntu, Daniel Duque Campayo, 12/12/2007
- Re: [cgal-discuss] CGAL and Ubuntu, Joachim Reichel, 12/12/2007
- Re: [cgal-discuss] CGAL and Ubuntu, Fernando Cacciola, 12/12/2007
- Re: [cgal-discuss] CGAL and Ubuntu, nt_mahmood, 12/12/2007
