cgal-discuss - Re: [cgal-discuss] CGAL and Ubuntu
  • To:
  • Subject: Re: [cgal-discuss] CGAL and Ubuntu
  • Date: Wed, 12 Dec 2007 15:42:15 +0100
Daniel Duque Campayo wrote:
>It's strange g++ is not installed if some g++-x.y is. But, you may try (as
>root):
>which g++-3.3
>answer: "path"/g++-3.3 (i.e., linux gives us the path to
>g++-3.3, /usr/local/bin or wherever).
I am new in ubuntu and I made a mistake installing packages. I found that
g++-3.3 is installed but g++ isn't!!
here is the output of "which":
mahmood@magma:~/Tools/cgal/$
sudo which g++-3.3
[sudo] password for mahmood:
/usr/bin/g++-3.3
> ln -s "path"/g++-3.3 "path"/g++ (replace "path" with path to g++-3.3).
> (make a "link" to g++-3.3 so now calls to g++ point to it.)
Joachim Reichel wrote:
>Please don't do this (at least if "path" if /usr/bin). Just install the
>g++ package.
I think Joachim is right. I now found that there is no g++ but g++-3.3 is
installed. I will install g++ ALONE and report problems if any.
Fernando Cacciola:
>The problem is that is not just g++-3.3 that needs to be aliased, there's
>also >gcc-3.3, cpp-3.3 and the correct 'ld' which maybe called just that...
Good tip... it is more difficult that I thought
Thanks,
