cgal-discuss - Re: [cgal-discuss] Nef Polyhedra test cases
  • To:
  • Subject: Re: [cgal-discuss] Nef Polyhedra test cases
  • Date: Wed, 9 Jan 2008 04:57:48 -0600
  • Domainkey-signature: s=main; d=mail.utexas.edu; c=nofws; q=dns; h=Received:Received:Received:Mime-Version:In-Reply-To: References:Content-Type:Message-Id: Content-Transfer-Encoding:From:Subject:Date:To: X-Mailer; b=i1Us9BjXLwIuQJ/SK1P4oC7oPOfA3CYF3sCN1/ZiD1ONdIIhhznuA qlTpN70YPMxx4K/tBuke8WXYl+gWYNywqsNrBiYyiI4DTVXvK8DCD 48Egse+HNHLBKYB3C5l6qPvbrdHR8D7YT6txBiCKsxPqTTJzIs/lQ 2brRAk53CZkI=;
Peter,
I just tried DNDEBUG and it reduced the time to convert the cat from off to nef down to ~30 seconds, which seems like it should make sense.
So, as the next entry in the never ending story, I just tried to perform the shark union with a much higher polycount shark model and discovered the following error upon trying to convert the result back from nef to off:
CGAL error: precondition violation!
Expr: it1.e_ == it2.e_
File: /usr/local/include/CGAL/iterator.h
Line: 563
Explanation:
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Line: 563
I'm using the following header consistently across all conversion programs and the set operations file:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Nef_3/SNC_indexed_items.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<Kernel, Items> Nef_polyhedron;
Sorry 'bout this.
-- Gilbert
On Jan 9, 2008, at 4:43 AM, Peter Hachenberger wrote:
Hi Gilbert,
I'm glad that I could help you. It's interesting to know that Gmp and
mpfr make such a difference.
Did you also add the option -DNDEBUG? This might again give you 20-40
seconds.
Peter
On Tue, 2008-01-08 at 23:55 -0600, Gilbert Bernstein wrote:
Sorry about spamming the list so much here.
Peter,
It seems the problem was the lack of gmp and mpfr. (from what I
understand they're mutually dependent inside of CGAL) After
installing those and rebuilding CGAL, all my programs worked
correctly without changing the code at all.
It takes me 80 seconds to convert robocat with -O2 set and using the
exact_predicates_exact_constructions kernel. This seems at least
within the realm of plausibility now. Do you have any
recommendations on trying to bring this number down closer to 20
seconds? Perhaps a particular Kernel is very well suited?
-- Gilbert
On Jan 8, 2008, at 6:03 AM, Peter Hachenberger wrote:
So, the robocat took less than 20 seconds on my notebook, which has 2
Ghz with only one Core. So, taking also your other mail into accout, it
seems that your CGAL installation might miss some important data types
and is therefore slower than necessary. Maybe the code I gave you in the
previous mail will not compile, because you don't have Gmp or some
similar problem.
Peter
On Mon, 2008-01-07 at 13:46 -0600, Gilbert Bernstein wrote:
Peter,
Here is the robocat (3756 vert 7512 tri) model, which I was able to
get through in half an hour. I was running another job along with
it, so it may not take that long, though it should take a good while.
I also tried a simplified shark model (1007 vert 2010 tri) which I
just measured at appx. 2 min to convert on my 1.83 Ghz Core Duo (not
Core2) (using only one core I believe)
-- Gilbert
On Jan 7, 2008, at 6:11 AM, Peter Hachenberger wrote:
Hi Gilbert,
half an hour is more than I would expect from a model of that size. I
have an example file that has about 2/3 of the size of your model and
the execution of handling_double_coordinates takes less than half a
minute. So, I'm a bit surprised. Can you please send me the file so
that
I can test it.
Peter
On Mon, 2008-01-07 at 03:47 -0600, Gilbert Bernstein wrote:
It seems I have to apologize for making such a stink here. It was
probably a false alarm.
I think I had unreasonable expectations on the speed of the
computation and thought the program had gone into a loop. I managed
to push a smaller model (3756 vertices 7512 triangles) through the
conversion both ways just now by waiting about half an hour. I also
know the model in question has some very funky joins between parts
(lots of long, close, sharp polygons) so I'm pretty sure this was
just a matter of patience. If only I was testing with the teapot.
Then I could make a really awful joke about watched teapots.
I just ran another model (1007 vert 2010 tri) through just fine, much
faster, so yeah...
-- Gilbert
On Jan 7, 2008, at 3:12 AM, Andreas Fabri wrote:
Gilbert,
It might be the best to just post a file that makes problems.
What is your OS/compiler, did you just take the example or
demo program, or write your own program? In the latter case
what kernel did you chooses?
andreas
Andreas,
I'm fairly sure all of the meshes I've tried are triangular
meshes, (I went back and checked a couple of them (since they're in
ascii) by eye) so I don't think that's the problem.
-- Gilbert
On Jan 7, 2008, at 2:10 AM, Andreas Fabri wrote:
Hello,
A typical problem is to have faces which are not triangular,
and at the same time not coplanar.
andreas
Hi,
I'm having an awful lot of trouble successfully building Nef
Polyhedra from .off input files. The only model I have
successfully translated from .off to a Nef Polyhedron and back is
a cube. I have tried a number of different models, all supposed
to be watertight, and which were certified by the
Polyhedron_3::is_closed() function. It certainly may be the case
that there was something off (ba dum chh) about these models, but
I've reached my point of frustration. If anyone has any known
working examples of importing models into the Nef Polyhedron type,
or any suggestions, I would much appreciate the tips.
-- Gilbert Bernstein
