cgal-discuss - RE: [cgal-discuss] CGAL example (simple_join_intersect)
  • To: <>
  • Subject: RE: [cgal-discuss] CGAL example (simple_join_intersect)
  • Date: Sun, 3 Feb 2008 14:44:49 +0800
Hi,
I installed Visual C++ Express 2005, then CGAL. However, after I got the
error, I installed VC Exp 2008 with CGAL installed and ran the application.
It still gave me the same error. Thanks for your help.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Sat 2/2/2008 11:51 PM
To:
Cc:
Subject: Re: [cgal-discuss] CGAL example (simple_join_intersect)
>I get the error message: "The application failed to start because
the application configuration is incorrect. >Review the manifest files for
possible errors. Reinstalling the application may fix this problem"
Hi,
I run it without any problem in VC 2005. What is the order of
installation: (VC installed then CGAL) or (CGAL installed the VC)? Did you
got any warnning during compilation and linking? please REBUILD the project
to see if there were any warnning.
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Saturday, February 2, 2008 5:48:58 PM
Subject: [cgal-discuss] CGAL example (simple_join_intersect)
Hi,
I am using CGAL 3.3.1 and MS Visual C++ Express 2008. When I try to
run the example simple_join_intersect under Boolean_set_operations_2, I get
the error message: "The application failed to start because the application
configuration is incorrect. Review the manifest files for possible errors.
Is there a dll to include or setting that I need to do before I run
the example? Some other examples run fine though. Thanks for your help.
Regards,
Kenneth
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete
the message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
<<winmail.dat>>
