cgal-discuss - Re: [cgal-discuss] CGAL example (simple_join_intersect)
  • To:
  • Subject: Re: [cgal-discuss] CGAL example (simple_join_intersect)
  • Date: Sat, 2 Feb 2008 22:59:00 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=gxWBlbLPUPakVJsOCWJ+jPu0iM5UB/ELIkhCvK8ND53zKQV3Nq/1rbGxDbCO2D09g2X1Baws1NM45WmGwH+DAdf9paYkIFXtqA0Z0LAzTRifroxd/pBXexbLjjMZMtXphLCL9Sc/VDpyv8U3KDEaAg160FZcG/jgyzY35wvBgB0=;
Hi,
It is strange...Did you get same error in 2005? Can you run other examples in
that directory? Can you write here Manifest section in project settings or
send a screenshot of it? and also a screenshot of linker->input
You did not say that did you get any warnning?
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Sunday, February 3, 2008 10:14:49 AM
Subject: RE: [cgal-discuss] CGAL example (simple_join_intersect)
Hi,
I installed Visual C++ Express 2005, then CGAL. However, after I got the
error, I installed VC Exp 2008 with CGAL installed and ran the application.
It still gave me the same error. Thanks for your help.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Sat 2/2/2008 11:51 PM
To:
Cc:
>I get the error message: "The application failed to start because the
application configuration is incorrect. >Review the manifest files for
possible errors. Reinstalling the application may fix this problem"
Hi,
I run it without any problem in VC 2005. What is the order of
installation: (VC installed then CGAL) or (CGAL installed the VC)? Did you
got any warnning during compilation and linking? please REBUILD the project
to see if there were any warnning.
Mahmood Naderan
To:
Sent: Saturday, February 2, 2008 5:48:58 PM
Subject: [cgal-discuss] CGAL example (simple_join_intersect)
Hi,
I am using CGAL 3.3.1 and MS Visual C++ Express 2008. When I try to run
the example simple_join_intersect under Boolean_set_operations_2, I get the
error message: "The application failed to start because the application
configuration is incorrect. Review the manifest files for possible errors.
Is there a dll to include or setting that I need to do before I run the
example? Some other examples run fine though. Thanks for your help.
Regards,
Kenneth
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
