- To:
- Subject: Re: [cgal-discuss] CGAL example (simple_join_intersect)
- Date: Sun, 3 Feb 2008 09:13:28 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=gV/S7UXhOJtmKgOba1/40CPlY1KHkCwqMtg21ylBo2UvL/Mh0i+xvxX+TfsbM773xwaw6T3WGC8f2RTqZSWHDY0t5fNamIh+wxPUaolG4+78W2Frl8GiQ00yBQ+JPn66pFpownB23EBhzWCdpHsg0fgzMCrn1A1JBaeo1nFsUNA=;
Hi,
You have to build "CGAL_80.sln" in "\src" folder. Then in
"Linker->input->additional dependencies" add the following entries:
CGALcore++-vc80-mt-gd.lib
CGALPDB-vc80-mt-gd.lib
cgalqt-vc80-mt-gd.lib
cgal-vc80-mt-gd.lib
But I have to say logically if these libraries were not added, linking should
have trouble and unresolved external symbol error must appear.
Try what I said. These are the same of me. I think that was the problem.
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Sunday, February 3, 2008 12:11:26 PM
Subject: RE: [cgal-discuss] CGAL example (simple_join_intersect)
Hi,
Yes, I got the same error in 2005. Attached are the screenshots. I'm not
sure which section for the manifest settings you were referring to, so I took
the general section. Do let me know if it is some other. I can actually run
the Polygon_2 examples. Also, I have tried to rebuild the libraries using
cgallib_80 project. However, it still gives me the same error. Thanks for
your advice.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Sun 2/3/2008 2:59 PM
To:
Cc:
Hi,
It is strange...Did you get same error in 2005? Can you run other
examples in that directory? Can you write here Manifest section in project
settings or send a screenshot of it? and also a screenshot of linker->input
You did not say that did you get any warnning?
Mahmood Naderan
To:
Sent: Sunday, February 3, 2008 10:14:49 AM
Hi,
I installed Visual C++ Express 2005, then CGAL. However, after I got
the error, I installed VC Exp 2008 with CGAL installed and ran the
application. It still gave me the same error. Thanks for your help.
Regards,
Kenneth
[mailto:]
Sent: Sat 2/2/2008 11:51 PM
To:
Cc:
>I get the error message: "The application failed to start because
the application configuration is incorrect. >Review the manifest files for
possible errors. Reinstalling the application may fix this problem"
Hi,
I run it without any problem in VC 2005. What is the order of
installation: (VC installed then CGAL) or (CGAL installed the VC)? Did you
got any warnning during compilation and linking? please REBUILD the project
to see if there were any warnning.
Mahmood Naderan
To:
Sent: Saturday, February 2, 2008 5:48:58 PM
Subject: [cgal-discuss] CGAL example (simple_join_intersect)
Hi,
I am using CGAL 3.3.1 and MS Visual C++ Express 2008. When I try to
run the example simple_join_intersect under Boolean_set_operations_2, I get
the error message: "The application failed to start because the application
configuration is incorrect. Review the manifest files for possible errors.
Is there a dll to include or setting that I need to do before I run
the example? Some other examples run fine though. Thanks for your help.
Regards,
Kenneth
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete
the message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/02/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/03/2008
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/03/2008
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/04/2008
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/05/2008
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/08/2008
