- To: <>
- Subject: RE: [cgal-discuss] CGAL example (simple_join_intersect)
- Date: Fri, 8 Feb 2008 22:52:17 +0800
Hi,
Thanks a lot for your help. I managed to run the example! I installed the
service pack 1 for VC++ 2005 Express and installed CGAL again. I then opened
the boolean set operations solution, and VC++ 2005 proceeded with the version
conversion. I then built and ran the simple_join_intersect project, and it
managed to run. I think the issue was probably the service pack 1? Thanks
again.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Tue 2/5/2008 5:10 PM
To:
Cc:
Subject: Re: [cgal-discuss] CGAL example (simple_join_intersect)
Hello,
You did not noticed what I said. please do the followings (I assume
you use VC2005):
1- install service pack for VS8. This service pack is not necessary
for building CGAL libraries, but you may face some confusing compiler errors
(ICEs, heap size errors, ...) in future works, so it is better to install SP1
now.
2- open "C:\Program Files\CGAL-3.3.1\src\CGAL_80.sln" and WITHOUT any
modification select "build->rebuild solution". Do not change project
settings. Please see the "lib.PNG" I attached and ensure that "additional
dependencies" are empty. What I understand from your reply is that you add
CGALcore++-vc80-mt-gd.lib and other lib files in the project settings. You
have to noticed that the purpose of building "CGAL_80.sln" is to create
library files in "lib" folder. You add non existing libraries to build them.
See what is the problem?
3- after buildng you will have CGAL library files. Now open
"simple_join_intersect" and add these library files (that I said in previous
mail) in "linker->input->additional dependencies":
CGALPDB-vc80-mt-gd.lib
cgalqt-vc80-mt-gd.lib
cgal-vc80-mt-gd.lib
4- now select "build->build simple_join_intersect".
thats it... Hope this can help you :)
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Monday, February 4, 2008 8:10:19 PM
Hi,
I have tried to build the cgal lib project in CGAL_80.sln. I have
also included the library files, but to no avail. Do I also need to install a
service pack for the express edition? Thanks for your help.
Regards,
Kenneth
[mailto:]
Sent: Mon 2/4/2008 1:13 AM
To:
Cc:
Hi,
You have to build "CGAL_80.sln" in "\src" folder. Then in
"Linker->input->additional dependencies" add the following entries:
cgal-vc80-mt-gd.lib
But I have to say logically if these libraries were not added,
linking should have trouble and unresolved external symbol error must appear.
Try what I said. These are the same of me. I think that was the
problem.
Mahmood Naderan
To:
Sent: Sunday, February 3, 2008 12:11:26 PM
Hi,
Yes, I got the same error in 2005. Attached are the
screenshots. I'm not sure which section for the manifest settings you were
referring to, so I took the general section. Do let me know if it is some
other. I can actually run the Polygon_2 examples. Also, I have tried to
rebuild the libraries using cgallib_80 project. However, it still gives me
the same error. Thanks for your advice.
Regards,
Kenneth
[mailto:]
Sent: Sun 2/3/2008 2:59 PM
To:
Cc:
Hi,
It is strange...Did you get same error in 2005? Can you run
other examples in that directory? Can you write here Manifest section in
project settings or send a screenshot of it? and also a screenshot of
linker->input
You did not say that did you get any warnning?
Mahmood Naderan
To:
Sent: Sunday, February 3, 2008 10:14:49 AM
Hi,
I installed Visual C++ Express 2005, then CGAL. However,
after I got the error, I installed VC Exp 2008 with CGAL installed and ran
the application. It still gave me the same error. Thanks for your help.
Regards,
Kenneth
[mailto:]
Sent: Sat 2/2/2008 11:51 PM
To:
Cc:
>I get the error message: "The application failed to
start because the application configuration is incorrect. >Review the
manifest files for possible errors. Reinstalling the application may fix this
problem"
Hi,
I run it without any problem in VC 2005. What is the
order of installation: (VC installed then CGAL) or (CGAL installed the VC)?
Did you got any warnning during compilation and linking? please REBUILD the
project to see if there were any warnning.
Mahmood Naderan
To:
Sent: Saturday, February 2, 2008 5:48:58 PM
Subject: [cgal-discuss] CGAL example
Hi,
I am using CGAL 3.3.1 and MS Visual C++ Express 2008.
When I try to run the example simple_join_intersect under
Boolean_set_operations_2, I get the error message: "The application failed to
start because the application configuration is incorrect. Review the manifest
files for possible errors. Reinstalling the application may fix this problem"
Is there a dll to include or setting that I need to do
before I run the example? Some other examples run fine though. Thanks for
your help.
Regards,
Kenneth
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
[This e-mail is confidential and may be privileged. If
you are not the
intended recipient, please kindly notify us immediately
and delete the message
from your system; please do not copy or use it for any
purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
<<winmail.dat>>
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/02/2008
- <Possible follow-up(s)>
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/03/2008
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/03/2008
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/04/2008
- Re: [cgal-discuss] CGAL example (simple_join_intersect), Mahmood Naderan, 02/05/2008
- RE: [cgal-discuss] CGAL example (simple_join_intersect), Kenneth Tham, 02/08/2008
