- To:
- Subject: Re: [cgal-discuss] Dual od Delaunay Edge 3D
- Date: Tue, 11 Mar 2008 16:15:14 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=o1m0LaOty+qPFjVqss7Pc/Pirr52zchBTzWWyz3q/bK9BnUrHvy0qJYSKLfs+whsE3VBI23Qt3jAZb8Pi/ICyKWmzI/GFPLOjY+lTsImIiqPaD5kQbqedKKNKBANlUlxQXmfjaUSo/4OuprUVE2Joz2eZEIpFyU2T6lLyX4xP3E=
Hi all,
it seems like the circulator is not actually circulating, I've done a simple test:
Edge e(*ci, v_ind1, ((v_ind1+i)%4) );
cc=T.incident_cells(e);
cc_end=T.incident_cells(Edge(*ci,v_ind1,((v_ind1+i)%4)));
cout << "------------------" << endl;
cout << (cc==cc_end) << endl;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cc++;
cout << " ------------------------" << endl;
and the output gives me something like this....
1
and then the program crashes. It seems like the circulator is not doing its job properly....
Any idea?
Thanks
Angelo
On Tue, Mar 11, 2008 at 12:03 PM, Angelo Tardugno <> wrote:
I've just tried the solution now, but I'm having problems with the circulator...here's a piece of my code:
T.incident_cells(vi,std::back_inserter(i_cells));
Cell_circulator cc;
Cell_circulator cc_end;
Point pt;
for (std::list<Cell_handle>::iterator ci = i_cells.begin(); ci!=i_cells.end();ci++)
//cout << T.is_infinite(*ci) << endl;
v_ind1=(*ci)->index(vi);
//cout << v_ind1 << endl;
for (int i=0; i<4;i++)
if (!(vert_set.count((*ci)->vertex((v_ind1+i)%4))))
vert_set.insert((*ci)->vertex((v_ind1+i)%4));
cc=T.incident_cells(Edge(*ci,v_ind1,((v_ind1+i)%4)));
cc_end=cc;
int n_cp=0; // I have to count the number of cells incident to write it on a file.....
do {
n_cp++;
cout << n_cp << endl;
} while (++cc!=cc_end);
medial << n_cp << endl;
cc_end=cc;
do
{ if (!T.is_infinite(cc))
pt=T.dual(cc);
cout << pt << endl;
medial << pt << endl;
else {cout << "Infinite Cell " << endl;}
medial.close();
Now I've got 2 problems....
The program compiles fine, but when I run it it crushes. This problem doesn't occur if I use cc++ instead of ++cc, but obviously the do-while just executes once and that's not what I want to do. The other problem is that if I direct a point not to the standard output but to a fstream I don't get any point on the file (but I think that probably point doesn't allow me to write the coordinates on a file...)
Thanks for your help and time
AngeloOn Tue, Mar 11, 2008 at 11:25 AM, <> wrote:
Hi
you got answers yesterday, didn't this help?
Monique Teillaud
wrote:
> Hello,
> I was wondering if it's possible to compute the dual of a Delaunay Edge in 3d. I've looked through the documentation but couldn't find anything. If this is not possible, how should I solve the problem?
> Thanks
> Angelo
- Dual od Delaunay Edge 3D, angelo . tardugno, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Andreas Fabri, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Monique . Teillaud, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Angelo Tardugno, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/11/2008
