- To:
- Subject: Re: [cgal-discuss] Dual od Delaunay Edge 3D
- Date: Mon, 10 Mar 2008 09:19:37 -0700
wrote:
Hello,
I was wondering if it's possible to compute the dual of a Delaunay Edge in
3d. I've looked through the documentation but couldn't find anything. If this
is not possible, how should I solve the problem?
Thanks
Angelo
Hi Angelo,
The triangulation
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html#Cross_link_anchor_963
offers a Cell_circulator
For a given Edge, it allows to traverse the circular sequence of cells
adjacent to the edge.
Traverse this sequence and call the "dual" method for the cells which gives
you
the sequence of Voronoi vertices describing the polygon.
Note that you must deal with the case of infinite cells, that is where the
polygon
is not closed.
andreas
- Dual od Delaunay Edge 3D, angelo . tardugno, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Andreas Fabri, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Monique . Teillaud, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Angelo Tardugno, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/11/2008
