- To:
- Subject: Re: [cgal-discuss] Dual od Delaunay Edge 3D
- Date: Mon, 10 Mar 2008 17:07:09 +0100
wrote:
Hello,> I've looked through the documentation but couldn't find anything.
I was wondering if it's possible to compute the dual of a Delaunay Edge in 3d.
No it doesn't exist because the dual of an edge would be a polygon which cannot be represented neither in the triangulation data structure nor in the kernel (correct me if it's wrong).
If this is not possible, how should I solve the problem?I must admit, I don't know your problem yet...
Best
Manuel
- Dual od Delaunay Edge 3D, angelo . tardugno, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Andreas Fabri, 03/10/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Monique . Teillaud, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Angelo Tardugno, 03/11/2008
- Re: [cgal-discuss] Dual od Delaunay Edge 3D, Manuel Caroli, 03/11/2008
