cgal-discuss - Re: [cgal-discuss] Dual od Delaunay Edge 3D
  • To:
  • Subject: Re: [cgal-discuss] Dual od Delaunay Edge 3D
  • Date: Tue, 11 Mar 2008 16:32:40 +0000
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=DwcqplzRCGDoHylcr81pMKIUKftI4CQiBptXhIb9oqLmw4LWTF44lzapIMBRRV/YPKKNcZiqxUKbT245qh6Wseh1ABsG2pkVehPnHMJYlna31gahtkURC7A18lO2omdSPB+/zWH9oMvj1DOklABQ/lhuV+rHRspxnO5jvTiDl6M=
Yes you're right....ci is an iterator of a list containing Cell handles. The rest of the code is here.
Thanks
Angelo
for (std::list<Cell_handle>::iterator ci = i_cells.begin(); ci!=i_cells.end();ci++)
            v_ind1=(*ci)->index(vi);
            for (int i=0; i<4;i++)
                //cout << *((*ci)->vertex((v_ind1+i)%4));
                if (!(vert_set.count((*ci)->vertex((v_ind1+i)%4))))
                    vert_set.insert((*ci)->vertex((v_ind1+i)%4));
                    Edge e(*ci, v_ind1, ((v_ind1+i)%4) );
                    cc=T.incident_cells(e);
                    cc_end=T.incident_cells(Edge(*ci,v_ind1,((v_ind1+i)%4)));
                    cout << "------------------" << endl;
                    cout << (cc==cc_end) << endl;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cc++;
                    cout << " ------------------------" << endl;
                    int n_cp=0;
                        //do
                        while ((++cc)!=(cc_end));
                            if (!(T.is_infinite(cc)))
                            ++n_cp;
                        } //while (&(++cc)!=&(cc_end));
                    cout << "Ciao" << endl;
                    medial << n_cp << endl;
                    cout << n_cp << endl;
                    cc_end=cc;
                    do
                        pt=T.dual(cc);
                        //cout << pt << endl;
                        xx = pt.x();
                        yy = pt.y();
                        zz = pt.z();
                       medial << xx << " " << yy << " " << zz << endl;
                    else {cout << "Infinite Cell " << endl;}
                    } while (cc++!=cc_end);
        //cout << i_cells.size() << endl;
On Tue, Mar 11, 2008 at 4:25 PM, <> wrote:
Hi,
It's difficult to say anything without knowing more about your code.
For instance, what is ci?
Angelo Tardugno wrote:
> Hi all,
> it seems like the circulator is not actually circulating, I've done a
> simple test:
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
>                     cc++;
> and the output gives me something like this....
> 1
> 0
> 0
> and then the program crashes. It seems like the circulator is not doing
> its job properly....
> Any idea?
> Thanks
> Angelo
