- To:
- Subject: Re: [cgal-discuss] Delaunay_triangulation_2
- Date: Sun, 30 Mar 2008 19:42:52 +0200 (CEST)
- Importance: Normal
At least with g++-4.1 on Linux-i686 32bit, I cannot reproduce the problem
(of adding the six points below), so it seems to be specific to the
platform you use ... can you post more details about it?
Note that for delaunay triangulation, exact predicates are sufficient -
exact number type/exact constructions are not required.
Best Regards,
Andreas Meyer
Louis Feng wrote:
> I compiled your code. I was able to reproduce the problem. I think the
problem is numerical accuracy related. As it has nothing to do with the
number of points you are inserting into the triangulation. In fact if
you
> try to add the following points, the same problem occurs:
> 6.68896e-005 1
> 6.68852e-005 2
> 6.68807e-005 0
> 6.68762e-005 1
> 6.68717e-005 2
> 6.68673e-005 0
> Maybe you need to use exact number types.
> Louis
>> -----Original Message-----
>> From:
>> [mailto:]
Sent: Saturday, March 29, 2008 2:28 PM
>> To:
>> Subject: [cgal-discuss] Delaunay_triangulation_2
- Re: [cgal-discuss] Delaunay_triangulation_2, Andreas Meyer, 03/30/2008
- Re: [cgal-discuss] Delaunay_triangulation_2, Ryan Henry, 03/30/2008
- RE: [cgal-discuss] Delaunay_triangulation_2, Louis Feng, 03/30/2008
- Re: [cgal-discuss] Delaunay_triangulation_2, Olivier Devillers, 03/31/2008
- Re: [cgal-discuss] Delaunay_triangulation_2, Serge Rehbinder, 03/31/2008
