- To:
- Subject: Re: [cgal-discuss] Surface Meshing
- Date: Sun, 13 Apr 2008 16:16:55 +0200
- Organization: INRIA Sophia Antipolis - Méditerranée
hi Philipp,
is it enough for you to have a polygon soup in off or obj format? or do you want a CGAL polyhedron as output (ie, oriented, 2-manifold)
Philipp Jenke a écrit :
Hello all,
I would like to transform the mesh created by example
File: examples/Surface_mesher/mesh_an_implicit_function.cpp
into a different data structure. Unfortunately, I just can't find the required documentation part telling me how to extract the surface triangles and vertices. Could someone help me out with a short code snippet?
Thanks a lot,
Philipp
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- Surface Meshing, Philipp Jenke, 04/11/2008
- Re: [cgal-discuss] Surface Meshing, Pierre Alliez, 04/13/2008
