cgal-discuss - Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • To: "" <>
  • Subject: Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • Date: Thu, 15 May 2008 09:55:09 +0200
Hi,
I am not an expert for Nef but AFAIK it does not need the kernel with sqrt.
It seems that the code is trying to decompose the Field type into Numerator and Denominator (for some reason),
but this is not possible for CORE::Expr.
Have you tried another kernel, i.e., one that is not using CORE::Expr as FT.
best,
Michael
Joe C wrote:
Hi, all
I run into some issue when using Nef_polyhedron_3 with Exact_predicates_exact_constructions_kernel_with_sqrt Kernel.
To be specific, here is the simple program I was testing:
#include <CGAL/Exact_predicates_exact_constructions_kernel_with_sqrt.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt Kernel;
typedef Kernel::Point_3 Point_3;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<Kernel, Items> Nef_polyhedron;
int main() {
Point_3 p( 1.0, 0.0, 0.0);
Point_3 q( 0.0, 1.0, 0.0);
Point_3 r( 0.0, 0.0, 1.0);
Point_3 s( 0.0, 0.0, 0.0);
Polyhedron P;
P.make_tetrahedron( p, q, r, s);
Nef_polyhedron N2(P);
return 0;
I am using Visual Studio 2003 and Visual Studio 2005 with CGAL 3.3.1. <http://3.3.1.> When runing in Release mode, everything runs fine. But when running in Debug mode, I got the following errors:
Is this a bug in CGAL or did I do something wrong? I can not figure this out, can anybody help me out?
Joe
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(300): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(305): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(310): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(315): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(323): error C2440: 'type cast' : cannot convert from 'std::allocator<_Ty>::value_type' to 'CGAL::Cartesian_base_no_ref_count<FT_,Kernel_>::FT'
with
_Ty=CGAL::Fraction_traits<FT>::Numerator_type
and
FT_=CORE::Expr,
Kernel_=CGAL::Simple_cartesian<CORE::Expr>
No constructor could take the source type, or constructor overload resolution was ambiguous
with
and
FT_=CORE::Expr,
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(324): error C2440: 'type cast' : cannot convert from 'std::allocator<_Ty>::value_type' to 'CGAL::Cartesian_base_no_ref_count<FT_,Kernel_>::FT'
with
and
FT_=CORE::Expr,
with
and
FT_=CORE::Expr,
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(306): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(307): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(308): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(309): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(311): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(312): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(313): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(314): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(316): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(317): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(318): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(319): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
with
C:\Program Files\CGAL-3.3.1\include\CGAL\float.h(133): warning C4244: 'return' : conversion from 'double' to 'CGAL::Algebraic_structure_traits_base<Type,Algebra_type>::Type', possible loss of data
with
Type=float,
Algebra_type=CGAL::Field_with_kth_root_tag
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(85): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(90): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(91): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\xtree(484): warning C4800: 'int' : forcing value to bool 'true' or 'false' (performance warning)
