cgal-discuss - Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • Date: Thu, 15 May 2008 14:16:58 +0200
Hi,
that's a correct analysis of Michael. Try the
Exact_predicates_exact_constructions_kernel; it should work. If you
really need the kernel with sqrt, you might need to wait for the next
release. The Nef_3 package has some functions that I intended as
features, but actually limit the number of applicable kernels. I will
try to make some of these features optional.
Peter
On Thu, 2008-05-15 at 09:55 +0200, Michael Hemmer wrote:
> Hi,
> I am not an expert for Nef but AFAIK it does not need the kernel with sqrt.
> It seems that the code is trying to decompose the Field type into
> Numerator and Denominator (for some reason),
> but this is not possible for CORE::Expr.
> Have you tried another kernel, i.e., one that is not using CORE::Expr as
> FT.
> best,
> Michael
> Joe C wrote:
> > Hi, all
> > I run into some issue when using Nef_polyhedron_3 with
> > Exact_predicates_exact_constructions_kernel_with_sqrt Kernel.
> > To be specific, here is the simple program I was testing:
> > #include <CGAL/Exact_predicates_exact_constructions_kernel_with_sqrt.h>
> > #include <CGAL/Polyhedron_3.h>
> > #include <CGAL/Nef_polyhedron_3.h>
> > typedef CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt
> > Kernel;
> > typedef Kernel::Point_3 Point_3;
> > typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
> > typedef CGAL::SNC_indexed_items Items;
> > typedef CGAL::Nef_polyhedron_3<Kernel, Items> Nef_polyhedron;
> > int main() {
> > Point_3 p( 1.0, 0.0, 0.0);
> > Point_3 q( 0.0, 1.0, 0.0);
> > Point_3 r( 0.0, 0.0, 1.0);
> > Point_3 s( 0.0, 0.0, 0.0);
> > Polyhedron P;
> > P.make_tetrahedron( p, q, r, s);
> > Nef_polyhedron N2(P);
> > return 0;
> > I am using Visual Studio 2003 and Visual Studio 2005 with CGAL 3.3.1.
> > <http://3.3.1.> When runing in Release mode, everything runs fine. But
> > when running in Debug mode, I got the following errors:
> > Is this a bug in CGAL or did I do something wrong? I can not figure
> > this out, can anybody help me out?
> > Joe
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(300):
> > error C2064: term does not evaluate to a function taking 3 arguments
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(305):
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(310):
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(315):
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(323):
> > error C2440: 'type cast' : cannot convert from
> > 'std::allocator<_Ty>::value_type' to
> > 'CGAL::Cartesian_base_no_ref_count<FT_,Kernel_>::FT'
> > with
> > _Ty=CGAL::Fraction_traits<FT>::Numerator_type
> > and
> > FT_=CORE::Expr,
> > Kernel_=CGAL::Simple_cartesian<CORE::Expr>
> > No constructor could take the source type, or constructor
> > overload resolution was ambiguous
> > with
> > and
> > FT_=CORE::Expr,
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(324):
> > with
> > and
> > FT_=CORE::Expr,
> > with
> > and
> > FT_=CORE::Expr,
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(306):
> > error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not
> > define this operator or a conversion to a type acceptable to the
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(307):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(308):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(309):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(311):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(312):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(313):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(314):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(316):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(317):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(318):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(319):
> > predefined operator
> > with
> > C:\Program Files\CGAL-3.3.1\include\CGAL\float.h(133): warning C4244:
> > 'return' : conversion from 'double' to
> > 'CGAL::Algebraic_structure_traits_base<Type,Algebra_type>::Type',
> > possible loss of data
> > with
> > Type=float,
> > Algebra_type=CGAL::Field_with_kth_root_tag
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(85): warning C4311:
> > 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to
> > 'unsigned long'
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(90): warning C4311:
> > 'unsigned long'
> > C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(91): warning C4311:
> > 'unsigned long'
> > C:\Program Files\Microsoft Visual Studio .NET
> > 2003\Vc7\include\xtree(484): warning C4800: 'int' : forcing value to
> > bool 'true' or 'false' (performance warning)
