cgal-discuss - Re: [cgal-discuss] Linking error in compiling TAUCS libs
  • To:
  • Subject: Re: [cgal-discuss] Linking error in compiling TAUCS libs
  • Date: Tue, 27 May 2008 11:34:25 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=vV6RaB8bWwnGyhhXlRbnIAogGheZtwBlaS41Ytx5OLax2A6O1izmxjftK3dwhNdHd3oNk6LAhk6HvFKBA+Vn04BfWfxzml9I2BKFSKyA6B5P9+MqQOJ7ol+mRR+yj/4hfR5h7P4H5hgdnxVUHjX22uRgZGSvM227CizYReg1pTQ=
Hi Saboret,
Thank you for your help. I've downloaded the package taucs_full.zip
from your ftp site.
You provide two .bat files in taucs_full.zip, one for win 32bit and
one for 64bit. According to the CGAL-README.txt, I should run the
win64 one as my IDE is VC++2005. But I have a little confusion. My OS
is window xp (32 bit). Does it matter? My CPU is Intel(R) Core™2 Duo
Processor (may support 64 bit).
Kevin
On 5/26/08, Laurent Saboret
wrote:
> Hi Kevin,
> My latest development version compiles happily with VC++ 2005 (32 and 64
> bits).
> Feel free to try it:
> ftp://ftp-sop.inria.fr/geometrica/lsaboret/cgal/taucs_for_CGAL_3.4_beta1
> Best regards,
> Laurent Saboret
> INRIA Sophia-Antipolis
> Kevin Xu a écrit :
> > Hi Saboret,
> > I'm using VC8 (2005). Is it possible to resolve this problem with VC8.0?
> > Thank you very much.
> > Kevin
> > wrote:
> > > Hi Kevin,
> > > A Google search of "error LNK2001: unresolved external symbol __ftol2"
> > > indicates that:
> > > If your source code includes a cast from double to long types, VC7 will
> > > generate a call to _ftol2.
> > > Indeed, build_taucs_win32_for_CGAL.bat expects to be called from a
> Visual
> > > C++ 7.1 prompt shell (see CGAL-README.TXT).
> > > Which version of VC++ are you using?
> > > Best regards,
> > > Laurent Saboret
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
