cgal-discuss - Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?
  • To: <>
  • Subject: Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?
  • Date: Wed, 28 May 2008 16:01:21 -0300
  • Organization: Geometry Factory
Hi Johan,
Hello All,
I followed the instructions on
(http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows)
for using Cgal (3.3.1) with Visual Studio Express 2008 using boost
1.35.00. And it seems to work fine.
However, if i compile and debug for example the straight skeleton demo
program, it seems a lot slower than it was previously.
"Previously" is what compiler, cgal version, etc?
It takes more
than two minutes to calculate the inner skeleton for the complex5
polygon (Vista, Core2Duo
2gig ram).
I suppose you are using checked iterators and the secure scl right?
Try defining _SECURE_SCL=0 and _HAS_ITERATOR_DEBUGGING=0, making sure to do the same when building CGAL itself.
If I compile and run
in release mode it doesnt even want to calculate any skeleton.
("Straight skeleton construction failed")
*any* skeleton no matter which one, like within a simple rectangle?
HTH
Fernando Cacciola
GeometryFactory
