- To:
- Subject: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?
- Date: Wed, 28 May 2008 17:57:28 +0200
Hello All,
I followed the instructions on (http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows) for using Cgal (3.3.1) with Visual Studio Express 2008 using boost 1.35.00. And it seems to work fine.
However, if i compile and debug for example the straight skeleton demo program, it seems a lot slower than it was previously. It takes more than two minutes to calculate the inner skeleton for the complex5 polygon (Vista, Core2Duo , 2gig ram). If I compile and run in release mode it doesnt even want to calculate any skeleton. ("Straight skeleton construction failed")
Does anyone have any explanation of what i am doing wrong, or a solution perhaps ?
regards,
Johan
Disclaimer: http://www.kuleuven.be/cwis/email_disclaimer.htm
- Linking error in compiling TAUCS libs, kevin . kai . xu, 05/25/2008
- Re: [cgal-discuss] Linking error in compiling TAUCS libs, Laurent Saboret, 05/26/2008
- Re: [cgal-discuss] Linking error in compiling TAUCS libs, Kevin Xu, 05/26/2008
- Re: [cgal-discuss] Linking error in compiling TAUCS libs, Kevin Xu, 05/27/2008
- Re: [cgal-discuss] Linking error in compiling TAUCS libs, Laurent Saboret, 05/27/2008
- [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?, Johan Verbert, 05/28/2008
- Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?, Fernando Cacciola, 05/28/2008
- Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?, Johan Verbert, 05/28/2008
- Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?, Ophir Setter, 05/29/2008
- Re: [cgal-discuss] CGAL 3.3.1 slow with VC++2008 ?, Fernando Cacciola, 05/29/2008
