- To:
- Subject: Re: [cgal-discuss] point lying over a line problem
- Date: Wed, 23 Jul 2008 19:51:21 +0200
Alejandro Aragon a écrit :
Naive???? Try to represent 0.1 exactly using a double precision type!
I said doubles are real, I did not say that reals are all representable as
double.
I guess we interpret "mathematical sense" differently.
Then you'll realize that as soon as you start using an inexact type, the strict "mathematical sense" Andreas was talking about really goes away...
I write a GFEM library and as you may know, as soon as you don't use standard FEM you need heavy computation involving geometry. A library should be written in a way that naive users as me (as you pointed out) would expect a point (usually represented by double types) to lie on top of a line within the same tolerance as the inexact type.
I would be surprised if it was possible to provide a relatively complete
and consistent model, that provides this property, apart from the exact
geometric computation road.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- Re: [cgal-discuss] point lying over a line problem, (continued)
- Re: [cgal-discuss] point lying over a line problem, Sylvain Pion, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Alejandro Aragon, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Olivier Devillers, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Fernando Cacciola, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Andreas Fabri, 07/23/2008
- Re: [cgal-discuss] point lying over a line problem, Camille Wormser, 07/23/2008
- RE: [cgal-discuss] point lying over a line problem, Xiaofan Li, 07/24/2008
