- To:
- Subject: Re: [cgal-discuss] Min_circle problem
- Date: Mon, 8 Sep 2008 09:49:40 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=Mjkc2gRBu1D3ejELRvp4Unf2HT9loYE3xAQmQ2X15RNt7iEXMv1m7dT9qqLAgrxlqx pb6NG9yNcdPljR44o1QBUws98U9cxDISiAsY01/4PJvqzS33S2a/KlpQOj0jWQyOopgW LH7RQGMyhq5c3VfXaLhcunCS300FSZxqIBnoI=
I defined
typedef CGAL::Gmpz NT;<copied from amnual>
I don't know what exactly it is though.
-Atul
On Mon, Sep 8, 2008 at 2:57 AM, Olivier Devillers <> wrote:
typedef CGAL::Min_circle_2<Traits> Min_circle; *
I defined Min_circle as per manual as follows
*typedef CGAL::Homogeneous<NT> K;
typedef CGAL::Min_circle_2_traits_2<Rep> Traits;
and what is NT ?
if NT is double or float please read the FAQ
http://www.cgal.org/FAQ.html#inexact_NT
- [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Olivier Devillers, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/11/2008
- Message not available
- Re: [cgal-discuss] Min_circle problem, Andreas Fabri, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/12/2008
- Re: [cgal-discuss] Min_circle problem, Michael Hoffmann, 09/12/2008
