- To:
- Subject: Re: [cgal-discuss] Min_circle problem
- Date: Thu, 11 Sep 2008 14:49:48 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=RQU8LuPnNuxLhD1slRTAUOP9nkXYrFJHJBdMGLPScff2tkCbd6OWDl7r4DhM8Jrtzh RdbKGq8PaN9CBAdV1MqVAcdvMMNo2pvHsaeaNU+tv9WRiQjogDPZy7Z1NmhFQ9UfMBtj 85dy3MxFE3jDfJLIv9oD+xOPOIru4qEgCjpjA=
Its my mistake.
I realized that I had some repeated points in my point set and I was expecting CGAL to take care of that. Now, I am checking my point set for all the points to be unique before applying Min_circle and it works.
Thanks.
-Atul
On Thu, Sep 11, 2008 at 2:42 PM, Atul Thakur <> wrote:
Hi:I am able to find out the case in which Min_circle is failing.Please find the code in the attachment.thanks,-AtulOn Thu, Sep 11, 2008 at 10:57 AM, Atul Thakur <> wrote:
I am using visual c++ (ver 8) and currently working in debug mode.-AtulOn Thu, Sep 11, 2008 at 9:37 AM, Andreas Fabri <> wrote:
Hi Atul,
what compiler do you use and are you in debug or release mode.
andreas
Atul Thakur wrote:
My program is huge and depends on ACIS as well.
I am trying to isolate the part thats crashing. As soon as I am done I'll send you the code.
Thanks for the reply.
-Atul
On Thu, Sep 11, 2008 at 3:03 AM, Bernd Gaertner< <mailto:>> wrote:
Atul Thakur wrote:
Hi:
Still facing the same problem of crashing when I use the
.Min_circle function of CGAL.
I'm responsible for this package (sorry for the late reply, I
was travelling). If you could send me a complete program with
input that crashes, I will look into it.
Best,
Bernd.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Olivier Devillers, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/11/2008
- Message not available
- Re: [cgal-discuss] Min_circle problem, Andreas Fabri, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/12/2008
- Re: [cgal-discuss] Min_circle problem, Michael Hoffmann, 09/12/2008
- Re: [cgal-discuss] Something about Segment_Delaunay_graph, brunokim.mc, 09/10/2008
