- To:
- Subject: Re: [cgal-discuss] Min_circle problem
- Date: Thu, 11 Sep 2008 14:42:42 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=KL32yksmcal5UpOCZDgCeG0ojoDJE9rASc47KMje9OQV35AE8h4dQpGgFpKEC6tNOE pUPH0Of+tygovF0jLqBWVmAizDO5MlZ9jx/YWUx/KW2OjVVG3bXtQPfsivvptyVJle1X /zUSCgruyd/gMHg81lS/0pbt3Ww/P/It4nttI=
Hi:
#include "iostream"I am able to find out the case in which Min_circle is failing.
Please find the code in the attachment.
thanks,
-Atul
On Thu, Sep 11, 2008 at 10:57 AM, Atul Thakur <> wrote:
I am using visual c++ (ver 8) and currently working in debug mode.-AtulOn Thu, Sep 11, 2008 at 9:37 AM, Andreas Fabri <> wrote:
Hi Atul,
what compiler do you use and are you in debug or release mode.
andreas
Atul Thakur wrote:
My program is huge and depends on ACIS as well.
I am trying to isolate the part thats crashing. As soon as I am done I'll send you the code.
Thanks for the reply.
-Atul
On Thu, Sep 11, 2008 at 3:03 AM, Bernd Gaertner< <mailto:>> wrote:
Atul Thakur wrote:
Hi:
Still facing the same problem of crashing when I use the
.Min_circle function of CGAL.
I'm responsible for this package (sorry for the late reply, I
was travelling). If you could send me a complete program with
input that crashes, I will look into it.
Best,
Bernd.
-- You are currently subscribed to cgal-discuss.
#include "CGAL\Cartesian.h"
#include "CGAL\Point_2.h"
#include "CGAL\Polygon_2.h"
#include "CGAL\config.h"
#include <CGAL\convex_hull_2.h>
#include <CGAL\Polygon_2.h>
#include <CGAL\Homogeneous.h>
#include <CGAL\Min_circle_2.h>
#include <CGAL\Min_circle_2_traits_2.h>
#include <CGAL\Gmpz.h>
using namespace std;
typedef CGAL::Cartesian<double> Rep;
typedef CGAL::Point_2<Rep> Point;
typedef CGAL::Polygon_2<Rep> Polygon ;
typedef CGAL::Gmpz NT;
typedef CGAL::Homogeneous<NT> K;
typedef CGAL::Min_circle_2_traits_2<Rep> Traits;
typedef CGAL::Min_circle_2<Traits> Min_circle;
list <Point> get_data()
list<Point> plist;
plist.push_back(Point(0, 0.0532667));
plist.push_back(Point(0.146312, 0.249703));
plist.push_back(Point(0.297471, 0.452645));
return plist;
int main()
for (int i=0; i<100; i++)
list<Point> ptlist;
ptlist = get_data();
Min_circle mc(ptlist.begin(), ptlist.end(), true);
cout<<mc.circle().squared_radius()<<"\n";
return 0;
- [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Olivier Devillers, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/08/2008
- Re: [cgal-discuss] Min_circle problem, Atul Thakur, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/11/2008
- Message not available
- Re: [cgal-discuss] Min_circle problem, Andreas Fabri, 09/11/2008
- Re: [cgal-discuss] Min_circle problem, Bernd Gaertner, 09/12/2008
- Re: [cgal-discuss] Min_circle problem, Michael Hoffmann, 09/12/2008
- Re: [cgal-discuss] Something about Segment_Delaunay_graph, brunokim.mc, 09/10/2008
