cgal-discuss - [cgal-discuss] Something about Segment_Delaunay_graph
  • To:
  • Subject: [cgal-discuss] Something about Segment_Delaunay_graph
  • Date: Mon, 8 Sep 2008 16:51:17 +0800 (CST)
Hi all:
   I am a beginner at CGAL, and find it a great library providing powerful algorithms for compute geometry. I tried to compile the Segment_Delaunay_graph_2 example(C:\Program Files\CGAL-3.3.1\examples\Segment_Delaunay_graph_2),but failed. The compile error is "error C2244: 'CGAL::Sdg2<Gt,ST,DS,LTag>::insert_point_on_segment' : unable to match function definition to an existing declaration". I tried to check the function declaration,but could not find anything wrong. Could someone help me? Thanks very much! Any suggestion is appreciated!
   regards.
        taojia
  pls see the soure code below:
 #include <CGAL/basic.h>
// standard includes
#include <iostream>
#include <fstream>
#include <cassert>
#include <string>
// define the kernel
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
typedef CGAL::Simple_cartesian<double>    CK;
typedef CGAL::Filtered_kernel<CK>         Kernel;
// typedefs for the traits and the algorithm
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
typedef CGAL::Segment_Delaunay_graph_traits_2<Kernel>  Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt>             SDG2;
using namespace std;
int main()
  ifstream ifs("data/sites2.cin");
  assert( ifs );
  SDG2          sdg;
  SDG2::Site_2  site;
  // read the sites from the stream and insert them in the diagram
  while ( ifs >> site ) { sdg.insert( site ); }
  ifs.close();
  // validate the diagram
  assert( sdg.is_valid(true, 1) );
  cout << endl << endl;
  // now walk through the non-infinite edges of the segment Delaunay
  // graphs (which are dual to the edges in the Voronoi diagram) and
  // print the sites defining each Voronoi edge.
  // Each oriented Voronoi edge (horizontal segment in the figure
  // below) is defined by four sites A, B, C and D.
  //      \         B         /
  //     C  -----------------  D
  //      /         A         \
  // The sites A and B define the (oriented) bisector on which the
  // edge lies whereas the sites C and D, along with A and B define
  // the two endpoints of the edge. These endpoints are the Voronoi
  // vertices of the triples A, B, C and B, A, D.
  // If one of these vertices is the vertex at infinity the string
  // "infinite vertex" is printed; the corresponding Voronoi edge is
  // actually a stright-line or parabolic ray.
  // The sites below are printed in the order A, B, C, D.
  string inf_vertex("infinite vertex");
  char vid[] = {'A', 'B', 'C', 'D'};
  SDG2::Finite_edges_iterator eit = sdg.finite_edges_begin();
  for (int k = 1; eit != sdg.finite_edges_end(); ++eit, ++k) {
    SDG2::Edge e = *eit;
    // get the vertices defining the Voronoi edge
    SDG2::Vertex_handle v[] = { e.first->vertex( sdg.ccw(e.second) ),
                                e.first->vertex( sdg.cw(e.second) ),
                                e.first->vertex( e.second ),
                                sdg.tds().mirror_vertex(e.first, e.second) };
    cout << "--- Edge " << k << " ---" << endl;
    for (int i = 0; i < 4; i++) {
      // check if the vertex is the vertex at infinity; if yes, print
      // the corresponding string, otherwise print the site
      if ( sdg.is_infinite(v[i]) ) {
        cout << vid[i] << ": " << inf_vertex << endl;
      } else {
        cout << vid[i] << ": " << v[i]->site() << endl;
    cout << endl;
  return 0;
买房不必东奔西走,上房老大,看"二手房"网上房展会
