cgal-discuss - Re: [cgal-discuss] triangulate points in a 3d plane
  • To:
  • Subject: Re: [cgal-discuss] triangulate points in a 3d plane
  • Date: Thu, 2 Oct 2008 10:12:42 +0200
Hi Shi,
I am not an expert with CGAL (yet), but I had the same problem. There are plenty
of triangulation methods in 3D (all of them work in 3d if I am not mistaken).
The resulting triangulation will be in 3D because infinite points will be added
to your point set. If you just check for these points (T.is_infinite(vertex))
and eliminating them should leave you with a triangulation in the plane.
Greetings,
Jens
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
Quoting Shi Yan
hello guys,
i need to do triangulation inside a 3d triangle. the triangulation
method provided by CGAL seems to be for 2D. so instead of me
converting the 3D points into a 2D coordinate system, is there any
convenient CGAL function that can do this for me?
thank you very much.
