- To:
- Subject: Re: [cgal-discuss] triangulate points in a 3d plane
- Date: Thu, 2 Oct 2008 16:30:37 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=C+GwN/vau4jivHJucu13XlRRvMg5TPPFKvnRcgdzOiVRa6xlToQmXKy4olP5tzw/56 zcRavZE/ilOJUcPsP3C6G9HpOeC69OhhGWVpW+rjVO0PTAP/nk4wpTOE+gqRGrWPoIlX VzhP2EVDQEaP1jKpdhNkLOdzqzxIx/w/1c95o=
thank you all.
i now have a new question, the triangulation methods use their own
data structure to represent the triangulation results. but in my
program, eventually i need to do the triangulation on polyhedrons.
so how can i map the triangulation result to the polyhedron facet
(insert new vertices and create new edges)? or is there any example
that i can check out?
thank you.
- [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Manuel Caroli, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Laurent Rineau, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Olivier Devillers, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/03/2008
- [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- [cgal-discuss] Polyhedra and join_facets, Jens K. Becker, 10/15/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Camille Wormser, 10/02/2008
