cgal-discuss - Re: [cgal-discuss] triangulate points in a 3d plane
  • To:
  • Subject: Re: [cgal-discuss] triangulate points in a 3d plane
  • Date: Thu, 2 Oct 2008 10:56:50 +0200
On Thursday 02 October 2008 10:38:26 Manuel Caroli wrote:
> Hi Shi Yan and Jens,
> just to clean up a bit:
> There is the Triangulation_2 package that computes triangulations in 2d
> and so needs 2d points.
That is quite an incomplete explanation. Triangulation_2 package can deal
with
coplanar 3D points, with an appropriate traits class. CGAL has three such
projection traits:
<CGAL/Triangulation_euclidean_traits_xy_3.h>
<CGAL/Triangulation_euclidean_traits_xz_3.h>
<CGAL/Triangulation_euclidean_traits_yz_3.h>
As for the original problem:
> i need to do triangulation inside a 3d triangle.
The solution is to use one of this three classes, depending on the normal
vector of the triangle: use <CGAL/Triangulation_euclidean_traits_xy_3.h> if
the nearest axis from the normal is z, and so on.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
