- To:
- Subject: Re: [cgal-discuss] triangulate points in a 3d plane
- Date: Thu, 02 Oct 2008 14:09:59 +0200
Jens K. Becker a écrit :
Yes, they are for tetrahedrons. Thats where the infinite points come in. If you
give the triangulation a set of points in a plane, the triangulation algorithm
will automatically insert points so that it can make tetrahedrons.
Theoretically, they are "just somewhere in space", meaning very far away from
the points you give it. It then uses your points and these infinite points to
make tetrahedrons. This leaves you with a set of cells (each cell is a
tetrahedron) and one point of each cell is an infinite point. Get rid of these
and you have triangulated your plane. Thats how I do it.
Jens
There is always exactly one point at infinity. If your points are coplanar
t->dimension() will be two and only the vertices 0,1 and 2 are meaningful (vertex 3 can be ignored).
If you want to triangulate coplanar 3D points, the best is to use 2d triangulation on 3d points as suggested
by Andreas, either with one of the suggested traits class (that basically ignore one coordinate) or
with your own traits class.
- [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Manuel Caroli, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Laurent Rineau, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Olivier Devillers, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/03/2008
- [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- [cgal-discuss] Polyhedra and join_facets, Jens K. Becker, 10/15/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Camille Wormser, 10/02/2008
