- To:
- Subject: Re: [cgal-discuss] Plane equations and cartesian<double> kernel
- Date: Thu, 2 Oct 2008 11:58:14 +0200
Plane(f1->halfedge()->vertex()->point(),f1->halfedge()->next()- >vertex()->point(),f1->halfedge()->prev()->vertex()- >point())==Plane(f2->halfedge()->vertex()->point(),f2->halfedge()- >next()->vertex()->point(),f2->halfedge()->prev()->vertex()->point())
to check if two facets are in the same plane, it crashes with
CGAL error: precondition violation!
Expr: circulator_size(h->vertex_begin()) >= size_type(3)
while trying to remove a halfedge
This means that you have degenerate faces, probably because some of the collapsing you did before was not acceptable, because the link condition was not satisfied.
(because the facets are not coplanar).
I think it is not related. The error relates to the combinatorial structure.
If I use f1->plane()==f2->plane(), it does not crash but does not find any
coplanar facets. Using typedef
CGAL::Exact_predicates_inexact_constructions_kernel K; for both cases.
I also changed the code to test first if they are adjacent and then if they are
coplanar, the problem remains...
By testing coplanarity, I mean calling CGAL::coplanar on the vertices, without computing the plane.
Camille
- Re: [cgal-discuss] triangulate points in a 3d plane, (continued)
- Re: [cgal-discuss] triangulate points in a 3d plane, Laurent Rineau, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Olivier Devillers, 10/02/2008
- Re: [cgal-discuss] triangulate points in a 3d plane, Shi Yan, 10/03/2008
- [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Jens K. Becker, 10/02/2008
- [cgal-discuss] Polyhedra and join_facets, Jens K. Becker, 10/15/2008
- Re: [cgal-discuss] Plane equations and cartesian<double> kernel, Camille Wormser, 10/02/2008
