cgal-discuss - Re: [cgal-discuss] How to install supported library for CGAL???
  • To:
  • Subject: Re: [cgal-discuss] How to install supported library for CGAL???
  • Date: Wed, 8 Oct 2008 02:30:07 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=LmTumMO+A1IGSiVTe8VTZZvLJfJtr0J63OfCPcbdE7mRzjUMhor7OHyMHMwXJ7L5Id34TuUyTUOQhOblEhAahr1rz9o7CudqfoXpTy7PVCEIyPe2rV75LbxKGs0YB/mWjDB5dIHBNxgQ839HuW3eaAQy2aMoWU9n3e6ISTwGnwc=;
Hello friends,
Thanks Roger. I tried to install CGAL via synaptic manager and all component works fine. I am just a new user in UBUNTU so I did not know much about synaptic manager.
Greetings,
Samay
----- Original Message ----
To:
Sent: Tuesday, October 7, 2008 4:59:58 PM
I recently decidedto install CGAL on Ubuntu 8.04, but first I checked with Synaptic and found that it was already installed. I guess as part of the upgrade to 8.04.  I've been compiling and running programs using CGAL ever since, and it has all gone quite smoothly.
Roger House
Samay Kumar wrote:
Hello Friends,
I am a bit new in LINUX and want to install CGAL on Ubuntu. I need a little bit help. I followed the procedure to install cgal-3.3.1 on linux http://www.cgal.org/Manual/3.3/doc_html/installation_manual/Chapter_installation_manual.html#sec:support-menu
While setup last screen was like...
** Compiling CGAL 3.3 **
OS: i686_Linux-2.6
COMPILER: GNU 4.2.3
BOOST: supported (1.33.1)
BOOST_PROGRAM_OPTIONS: supported (1.33.1)
BOOST_BIMAP: not supported
X11: supported (11.0)
GMP: supported (4.1.4)
GMPXX: supported (4.1.4)
MPFR: not supported
ZLIB: not supported
BLAS: not supported
LAPACK: not supported
ATLAS: not supported
LEDA: not supported
LEDAWIN: not supported
OPENGL: supported (2.0)
QT: not supported
TAUCS: not supported
Some of library as shown RED above can not be installed. I have tried to install those library from Synaptic manager and run the install_cgal. Unfortunately again the same error.
I have downloaded..
gmp-4.2.4.tar.gz
    mpfr-2.3.2.tar.gz
    taucs_full.tgz (from CGAL download site)
I dont know how to isntall these packages. Kindly help some one. I have also attached picture of BLAS, LAPACK and ATLAS status on my laptop from synaptic package manager. But still while installing CGAL installer says "not supported". Also give hint how to install these BLAS, LAPACK and ATLAS to get it supported while isntalling CGAL.
Greetings,
samay
