- To:
- Subject: [cgal-discuss] Vertex_handle
- Date: Tue, 7 Oct 2008 18:55:41 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=gvanGhEOWr0mAYX/pFPB+URZipoue2zX9+AMmyKsdwTjJyM67GQuLN99OFWFoJoXJr Sc07P7v6dUbBOsSumvg7teE7uF2JBxKgyGYIo/IlCw8u3qxYPmTx//UGmlARD3Yrtwpe kDfRAkuNkOKT9D9hexIXOFdaRc6duDOjqYRec=
Hi all,
I was going to answer but I see that again, our friend Andreas was
faster. Thanks again.
I think the documentation about Vertex_handle is not clear, is maybe too
hidden.
What is the definitive pointer to the doc on Vertex_handle? (Same
applies to Edge).
Searching in ~3500 pages of documentation is not s easy! :D
Anyway, the Library is great and is very easy to use! Just a little
rough at the beginning!
Thanks!
JPi
On Tue, Oct 7, 2008 at 5:38 PM, Andreas Fabri
wrote:
> Dennis Endt wrote:
>> Hi,
>> thats my Problem:
>> /typedef CGAL::Simple_cartesian<double> SK;
>> typedef CGAL::Filtered_kernel<SK> FK;
>> struct K : public FK {};
>> typedef K::Point_3 dPoint;
>> typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
>> typedef Triangulation::Vertex_handle Vertex_handle;
>> Triangulation T;
>> list<Vertex_handle> vertices; // vector to hold the points of the convex
>> hull
>> T.incident_vertices(T.infinite_vertex(), back_inserter(vertices)); //
>> get the points from Delaunay/
>> Can anyone plz tell how I get access to the points corresponding to the
>> vertex_handles? It is very urgent.
>> I tried everything so far...it cannot be so difficult ;)
>> Best Dennis
> for(list<Vertex_handle>::iterator it = vertices.begin();
> it != vertices.end();
> ++it){
> std::cout (*it)->point() << std::endl;
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] How to install supported library for CGAL???, Samay Kumar, 10/07/2008
- Re: [cgal-discuss] How to install supported library for CGAL???, Roger House, 10/07/2008
- [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Manuel Caroli, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/07/2008
- Message not available
- [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/08/2008
- [cgal-discuss] Redudant Points, Dennis Endt, 10/08/2008
- Re: [cgal-discuss] Vertex_handle, Monique Teillaud, 10/09/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] How to install supported library for CGAL???, Samay Kumar, 10/08/2008
